Use Alesis Trigger iO with Superior Drummer 2
2011-08-02 12:01:50
A user asked this:
Alesis Trigger iO, and superior drummer 2, and there is an incompatibility issue between the two of them.
For variable Hi-Hat sounds, the Trigger iO sends a 0~128 signal separably from the cymbal signal (I couldn't understand how that 0~128 works in therms of MIDI), which indicates the expression of the Hi-Hat cymbal (from fully open to fully closed). The Superior Drummer 2 can only receive 4 separate notes (fully open, fully closed, half open, half closed) for the Hi-Hat cymbal.
My question is, can I use your software to remap both MIDI notes into each of the 4 notes?
Trigger iO                                        Supperior Drummer
Cymbal               expression
    on                  0~32                         MIDI note A
    on                  32~64                        MIDI note B
    on                  64~96                        MIDI note C
    on                  96~128                       MIDI note D
2011-08-02 12:13:55
This is quite easy with Midi Translator Pro!
This is the straight-forward way:
Translator 1: Hihat state 1
Options: stop=false
Incoming: MIDI 90 40 pp
  if pp>32 then exit rules, skip Outgoing Action
Outgoing: MIDI 90 01 7F
Translator 2: Hihat state 2
Options: stop=false
  if pp<=32 then exit rules, skip Outgoing Action
  if pp>64 then exit rules, skip Outgoing Action
Outgoing: MIDI 90 02 7F
Translator 3: Hihat state 3
Options: stop=false
  if pp<=64 then exit rules, skip Outgoing Action
  if pp>96 then exit rules, skip Outgoing Action
Outgoing: MIDI 90 03 7F
Translator 4: Hihat state 4
Options: stop=false
  if pp<=96 then exit rules, skip Outgoing Action
Outgoing: MIDI 90 04 7F
This will send MIDI notes 01, 02, 03, or 04, depending on the velocity range of the Note sent by the Trigger iO. Replace the Outgoing Note number with what you need!
I assume the Trigger iO note is 0x40 (hexadecimal), i.e. Note 64 (decimal). You can use MIDI Capture in the Incoming action to get the note directly from the Trigger iO. Then replace the third number with the pp local variable.
For every outgoing note, there is one Translator Entry. That makes it easy to understand and to modify. The outgoing velocity is always full velocity. There is no Note Off.
Hope that gives an idea!
2011-08-02 12:20:27
I guess that the Trigger iO sends different velocity for how hard you play. So if in range 0..32, 32 will be the hardest for that hihat type and 33 will be the lowest for the second hihat type.
If you want that, you can add rules to calculate an outgoing velocity:
Options: stop=false
  qq=pp*4
  if qq<1 then qq=1
  if qq>127 then qq=127
Outgoing: MIDI 90 01 qq
Options: stop=false
  qq=pp-32
  qq=qq*4
Outgoing: MIDI 90 02 qq
Options: stop=false
  qq=pp-64
  qq=qq*4
Outgoing: MIDI 90 03 qq
Options: stop=false
  qq=pp-96
  qq=qq*4
Outgoing: MIDI 90 04 qq
I guess you see from this example how the velocity can be mapped.
pedrocalejon
2011-08-02 17:28:22
Hey guys.... thanks a lot for the attention!
One more thing... will this all work on win7 64bits?
2011-09-14 18:17:09
fwiw (late reply...)
Yes, Midi Translator works fine on Windows 7 (32-bit and 64-bit)
