TomT
2011-08-09 00:36:01
Hi to all,
I´m newbie here and need a solution with one thing.
I work with a midi-sensor-box from eowave, to capture signals from different sensors and sending them via midi from one pc to another.
The midi signal, the sensor box is sending, is a control change.
Now I checked out that it is possible with bome´s midi translator, to send a keystroke as a midi signal.
Is it possible to send a mousewheel-action too?
What I need is:
when the mousewheel is scrolled up with each step of the mousewheel a controlchange-signal (127) should be send on chanel 3 and controller 3,
when the mousewheel is scrolled down with each step of the mousewheel a controlchange-signal (0) should be send on chanel 3 and controller 3.
Could someone please help me with that.
Thanks in advance!
Cheers Tom
What I need is:
Thanks in advance!
Cheers Tom
