Nonspacial
2011-09-08 04:27:00
Hello all new world of joy,
You get this a lot and it will continue to happen: today I am the Noob with more questions than brain cells to fathom them.
Overview of what i want to do:
Run My APC40 as the controller for both Traktor and Ableton (possibly in the future Grand VJ, but lets not get ahead of ourself) simultaneously.
I have mapped my Apc to Traktor quite successfully and am now looking into running it for ableton as a way of Live hashing of loops i have created myself. i have a copy of Bomes 1.7.1 and am damn well sure this is possible.
Setup currently is a little complex in terms of virtual midi cables so it goes:
APC -> Bomes -> Bomes Virtual Midi I/O 1 -> ableton, simple enough
APC -> Bomes -> Bomes Virtual Midi I/O 2 -> Str8updrew's Send Monitor State Max Patch Fix (i'm on PC) -> Midi Yoke 1 to Traktor and Midi Yoke 2 Out of Traktor (this works fine i have tested it)
So what i need to know and do is isolate the 2 Virtual Midi Cables and update the APC by the Push of a button so i control and see one program and then the other.
currently i had so much trouble getting off the ground with even a modifier in this program i am eternally grateful to Debrecini for their post APC40 Help with additional banks / modes
which is the only post i have seen to include an actual starting point (or indeed any sort of uploaded preset) unlike Traktor: people are far more precious about their .bmtp's than .tsi's, which unfortunately doesn't help us that need to take things apart to learn from them.
anyway sorry for the gripe there, so i have uploaded here what i think i need to add to that .bmtp to make this work i.e. 2 presets called Ableton and Traktor, and i have made 2 extra shift translators that work on the record arm button of Track 7 on the APC, by turning this LED on i hope to use Ableton and Off use Traktor. This button is not mapped in Traktor for me and so works well with LED feedback to say what i am doing.
I have also changed the shift modifier to the Stop All Clips button and moved the Load Deck buttons in my tsi to free this button back up, on DJ Tech Tools it is Load Deck D/Unload Deck D and has a corresponding Deck Select if you want to move these to test please do.
i am hoping either someone already knows what i need to do and can put screenshots up/send me their .bmtp to see how they did it, or that maybe you will download my TSI and this .bmtp and be able to direct me from their.
Once this is all done i will get on with making the Banks for my traktor mapping work again as i'm sure the ableton handshake will screw things up, any advice on this also much appreciated, then i want make the Banks for ableton itself, the drum machine from the most famous video etc again any advice gratefully received.
Thanks very much for any time you may put into me i will make my .bmtp freely available as i expand it.
Robbie
My TSi can be found here both MAC and PC versions available make sure you have the Send monitor state Fix if your on pc and MIDI Yoke i think Page 5 or 4 of the thread has all the details, look for the mediafire link
http://www.djtechtools.com/forum/showth ... 817&page=6
Robbie
- Attachments
- BOME APC 40 Robbie Basic.bmtp
- (149.15 KiB) Downloaded 472 times
