ZuluCompany
2011-09-11 18:36:45
I'm using MT Pro to translate some midi buttons on my Allen and Heath Xone4D mixer/MIDI controller into keystrokes for Ableton Live. The reason for this is I want to turn devices on and off with a single press/depress of the midi button. (Instead, all midi in Ableton is natively a note on message on the first press, then you have to press the button again to send the note off). Therefore I mapped a key, like "a", to the on/off of a beat repeat. In MT Pro I then press the midi button i want to use to get the note on message, translate that to the key "a", then make another translator for the same button, but this time the note off message, and translate it to "a". So now when I press the midi button down it turns the device on and when i take my finger off the button, it turns the device off.
It seemed to be working well however the problem is, very often, the beat repeat device i am controlling with the midi button gets stuck. As in i'll press to turn the device on, then let go to turn it off but it remains on. Now it's completely flipped so when i press the button, it's turning off and then back on, I have to go in with my mouse and turn the device off to get it back. I checked my system/midi/cables and have not been experiencing any problems or latency, i can only guess the problem is coming from Bomes itself. It feels as if I press the button at a certain speed, it won't catch the note off signal, leaving my device in ableton turned on. Is there anything i can do to remedy the situation? If it weren't for this issue, everything would be working absolutely flawlessly and i really like having this control in ableton, but with this kind of problem it's a bit too unreliable for a live situation. Thanks!
