bsfreque
2011-10-16 02:14:42
Midi router is great, but It would be cool to be able to turn individual midi routings on and off with midi commands. This way I could for example use my APC40 in native mode with ableton, and also use it to control my hardware gear, to select sounds etc. simply by pressing the shift button, that would trigger the input routing to ableton to turn off, and turn another preset on in MT.
Also good for other purposes as well, and it would add a lot more flexibility to the software.
(I'm using the mac version of MT.)
Edit: No worries! I was able to do this by mapping everything from the APC40 controller to MT and using the 'swallow MIDI message' - function.
Still, it would be handy to be able to easily switch routings on and off. Setting up would be a lot easier and faster in many cases.
