DeRoc
2011-11-19 07:18:55
This might be related to the problem you fixed a couple of years ago http://www.bome.com/forums/viewtopic.php?f=4&t=2520
In the "Outgoing Action Preset Change", setting Activate/Deactivate by Name works EXCEPT for "(always active)". I noticed the parenthesis is translated to a "quoted-bracket" after the action occurs, as follows from the log.
Using By Number: <-- works normally
I love MT and use it for everything!
MT v1.71 on Win7 x64.
- OUT 3.0: deactivate preset number 0
Deactivated preset: (always active) <-- parentheses
OUT 3.1: deactivate preset "ON"
Deactivated preset: ON
- OUT 3.0: deactivate preset "[always active]" <-- brackets and quotes appear
Cannot find preset named "[always active]"
