gburks
2012-01-05 11:03:42
I'm trying to get my old Yamaha 01v digital mixer working as a MIDI Controller for Pro Tools using MT Pro. I am very close to making this work, and I'll share the template here once its working. I'm using MT to convert the 01v incoming MIDI to HUI across two instances of HUI controllers in Pro Tools.
The problem I have is that when I grab the motorized fader and try to move it, the fader "fights" back. Some MIDI feedback loop is occurring because the mixer is sending a message to Pro Tools, and Pro Tools is sending the same message back to the fader, and the screen and fader are fighting to update each other.
What is the best way to fix this?
I have two presets in my MT project, one for converting 01v to HUI, and another for converting HUI back to 01v. It seems like if I could temporarily disable the second preset anytime the first preset received input, it would work.
By the way I referenced the Allen & Heath GR-24 Pro Tools translator preset for inspiration, available under the documents tab here:
http://www.allen-heath.com/uk/products/ ... ctId=GSR24
Graham
Graham
