julynessi
2012-01-05 17:16:42
Just Sharing If you want to try
Remote (Zero) SL - Traktor Pro 2 FX Display Template. Bome's MT File.
This Zip contain 2 files
1.Traktor Pro TSI
2.Bome's Preset File
you'll need "Novation Remote SL (I build from ZeroSL but It can use With any SL)"
and Traktor Pro 2 with "Default FX Setting"
This Template Support 4FX Units (but It works only Group FX...It can be done in any Fx mode but I'm lazy)
Import each map to each programs. Just that.
1.Traktor Pro TSI
- Attachments
- BomeTSI.zip
- (40.85 KiB) Downloaded 446 times
