Audios
2012-01-16 04:01:36
Hi, I believe I’ve found two bugs.
First, one bug relates to the generation of CTRL+Up and CTRL+Down keystrokes, which I am using to adjust the volume of iTunes 10.5.2.11 on a PC with Win 7 (64 bit). My PC is a Core i7-920 with 12 GB RAM.
MT recognizes MIDI messages from my Roland FC-300 but when MT outputs “Ctrl(Up )” or “Ctrl(Down )” keystrokes in response to pedal presses, iTunes ignores 99% of them. If I press the FC-300 pedals very quickly (each of which should cause a step increase/decrease in volume, depending on the pedal), iTunes’ volume only changes once in a blue moon.
Needless to say, I don’t experience the same effect with my computer keyboard. Every time I press CTRL+Up (or Down), iTunes’ volume changes accordingly.
I discovered that if I sent a huge number of “Ctrl(Up )” or Down keystrokes by using a timer with a 10 msec delay, then iTunes does respond but still not smoothly, as if it’s ignoring the vast majority of keystrokes.
Other than the problem with controlling the volume, I’m able to control iTunes play/pause, next song and rewind/previous song functions with my FC-300. Very slick while I’m playing along to tunes with my guitar, especially since I’m simultaneously able to control two different effects boxes with other FC-300 pedals!!!
The second bug: if my computer goes to sleep while MT is running, MT is unresponsive when I wake my computer. Several times, even Task Manager was unable to shut the program down. MT appears in the list of Task Manager’s “Running Applications” but “End Task” won’t kill it. The only solution has been to reboot.
Keep up the good work. I love this program!
Audios
Audios
