Xone
2012-01-17 17:17:11
Hi everybody...
I would like to use my APC20 with a Lightning Program (Freestyler DMX)
My Problem is:
the APC20 send out two Midi signals when i push and release a knob (Note on /Note off),
My DMX Lightning program sends only 1 singnal for example "Flash Button 1" Note: B0 30 00 for Note on and OFF
example ( i activate it, send B0 30 00, i disabled it ,send B0 30 00)
I am thinking about this.
At start the Knob is green , i push the knob on the apc it will be flashed red and the "Flash Button 1 " is aktivated on my Program.
then
i will push the apc knob again , then he will green again and the "Flash button 1 " is disable.
Do you know what i mean ?
I hope you understand my english
I have install the Translator version 1.71 and midi yoke
My Problem is:
then
