mrjixies
2012-02-23 12:31:19
Hi all,
I just purchased MT Pro. However I can't get the virtual ports working with my DAW? I have a Device that needs a direct connection with my Daw. I used LoopMidi before this without any problems. Also it works while using LoopMidi and MT Pro at the same time. But when solely using MT Pro Virtual port's it doesnt work. I'm oke with using LoopMidi as well, but It would be a lot nicer (especially in live setups) to just use MT Pro.
My (OLD) Setup is as follows
DEVICE (Ipad Lemur)
--- connected to loopmidi port 1 (in) and port 2 (out)
DAW
--- receives from port 1 and sends to port 2
I can connect the Ipad Lemur to Bome's Midi Translator 1 and to 2- Bome's Midi Translator 1 without any problems, but when I select the port in my Daw (presonus studio one v2) I get an error saying "failed to connect to midi port"
Am I doing something wrong? Or is MT Pro not able to act as an midilooper?
Thanks for the help in advance!
DEVICE (Ipad Lemur)
DAW
