Reverse MIDI notes (right to left)
2012-05-17 20:47:59
A user asks:
Can MIDI Translator reverse Midi notes in a midi controller?
So it would be possible to play my keyboard like left handed?
2012-05-17 20:52:33
this is rather simple. You need MIDI Translator Pro.
You need the typical setup where MIDI Translator sits in between your MIDI keyboard/controller and the software you want to play in. Check the user manual (or search this forum) for details.
Then, create a preset and in it, create 2 translators like this:
Translator 0: Reverse Note On messages on MIDI Channel 1
Incoming: MIDI 90 pp qq
 [x] swallow incoming message
 pp=127-pp
Outgoing: MIDI 90 pp qq
Translator 1: Reverse Note Off messages on MIDI Channel 1
Incoming: MIDI 80 pp qq
 pp=127-pp
Outgoing: MIDI 80 pp qq
In both translators, pp captures the incoming note number. The rule will reverse it by subtracting it from 127 (127 is the maximum note number). pp is the velocity of the played note. The outgoing action will output the new MIDI message.
chilly7
2012-05-17 21:14:27
Hello
Thank u for the quick replay.
but it does not work.
I sent u a file by e-mail, did i do something wrong?
p.s. I do not own this program yet, i use trial version, but for that feature i am going to buy the program alone
chilly7
2012-05-17 22:54:47
now i use Ableton 8
in ableton 8 in Preference-> Midi
I use only "Bomes Midi translator 1"
so if i disable it, there is no sound if i eneble it there is a sound. ( so that means it works)
in Bomes Midi translator
i go to Midi Router
and then link 2 Axiom Pro 61 USB A in to Bomes MIDI Translator 1 virtual out
2012-05-18 23:05:52
thanks for the notification by email. I've updated the description above, it only works on MIDI channel 1.
To make it work on channel 16, for example, replace all "9F" and "8F" with "90" / "80".
chilly7
2012-05-18 23:39:06
florian wrote:thanks for the notification by email. I've updated the description above, it only works on MIDI channel 1.
Thank Florian
P.s. What about chanell 2 are. Numbers will be changed? :mrgreen:
Because I am planing to add second Midi controller to my setup in a month , will it be able to work with two Midi controller which probably will be assigned to two midi Chanels, 1 and 2 ?
2012-05-19 00:31:39
yes, it'll work with as many MIDI controllers as you like.
Many users actually use MIDI Translator mainly to consolidate all their MIDI ports.
For MIDI Channel 2, replace 80/90 with 81/91.
Now why is that so? You can Google for MIDI Note-On hex to get some insight :)
chilly7
2012-05-19 00:41:47
florian wrote:yes, it'll work with as many MIDI controllers as you like.
thank u.
I complitely do not understand MiDi stuff, so extreme thanks for help
Have a nice day and extreme thanks again
