makerprofaze
2012-06-06 05:49:07
Hi all. I've set up a 'matrix' or 'radio button group', but in order to deactivate the presently activated button, I have to bang/deactivate All the buttons. I'm wondering how I could add a variable to discretely turn off the active button then activate the next in a simpler manner.
Here is a short form example.
Translator 0.0: Btn 0 In
Options: stop=false
Incoming: MIDI 90 00 7F
ga=0
Outgoing: Select Timer
Translator 0.1: Btn 1 In
Options: stop=false
Incoming: MIDI 90 01 7F
ga=1
Translator 0.2: Btn 2 In
Options: stop=false
Incoming: MIDI 90 02 7F
ga=2
Translator 0.3: DeActivate LED
Options: stop=false
Incoming: One-shot timer "Select Timer"
Outgoing: MIDI 90 00 00 90 01 00 90 02 00
Translator 0.4: Activate LED
Options: stop=false
Outgoing: 90 ga 7F
The thing is that I have 64(+) nodes in some matrices and, while this method does work effectively, sometimes it causes audio to hiccup as multiple matrices are switching at the same time and sounds are simultaneously being triggered from the same core event.
I've been trying to formulate a second global variable to hold the active global variable numeric, but I can't figure out the order/timing to make it work.
Any input is greatly appreciated.
Options: stop=false
ga=0
Options: stop=false
ga=1
Options: stop=false
ga=2
Options: stop=false
Options: stop=false
Outgoing: 90 ga 7F
