doombadger
2012-06-30 14:31:22
Hi there guys,
As I'm sure no one really knows I've been quietly working away on my own project, scripting presets for the APC40, SL Mk2 and SCS.3 system for Ableton Live AND Traktor Pro. As I'm pretty much learning as I go everything is taking twice as long as it should and is being built, scrapped and rebuilt at least three or four times as my understanding starts to catch up with my expectations. Consequently, it's still not ready for release into the wild.
But, I do want to get something out so who would like some of this:
SCS.3d & SCS.3m Preset for Traktor Pro & Ableton Live
- taken from the master template: 'New Beginnings: Open Source MIDI Control Project'
SCS.3d Decks A & B: Traktor Control
If anyone wants this I'll need to isolate the SCS.3 translators from the main project and create one just for the Stanton which I reckon should take me a day. If this is something people are keen to have then make some noise and show some love and I'll get it up there for all you lovely people to have a play with.
All feedback, ideas, suggestions, criticisms, complaints, rants and sexual advances welcome.
doombadger - damagedgoods
- -FX modes 1 / 2 - Trigger, Select, Control
- -Loop mode 1 / 2 - As standard SCS presets.
- -Vinyl mode 1 / 2 - Scratch & Bend Control. Phase Monitor LED Feedback
- -Trigger mode - Set, Save, Cycle & Jump To cue points.
- -EQ1 mode - File Browse & Load into Deck A or B.
- -EQ2 mode - **Not Mapped(coming soon)
- -Tempo Control - Auto Pitch Sync or Manual Beat Match selection.
- -C & D mapped as controllers for Track/ Device / FX control in Live(coming soon)
- -Dedicated Track Level control for Audio input channels from Traktor. Track assignment hardcoded using python remote script ClyphX from Stray at nativeKONTROL.
- -3 Band DJ EQ modified from original by Terakith with LOW/MID/HIGH Kills & one touch restore. Kills can be either momentary or toggle. EQ page remembers settings and recalls correct LED feedback.
- -Allen & Heath style filter sweep adapted fromn original by Tarekith. OneTouch ON/OFF control, can be set to momentary or toggle activation.
- -Send/Return Control for FX sends A,B,C and D - Slider and button functionality for dry/wet FX or ON/OFF. Also can be momentary or toggle and FX page remembers settings and recalls correct LED feedback.
- -Fade2Distort effect originally from S4racen at Isotonik Studios.
- -Almost all controls are set to relative2comp for sensitive adjustments.
- -SCS.3d: Decks C & D mapped as controllers in Live
- -SCS.3m: Mapping and assignments for layers C and D to Ableton.
- -Custom remote control surface python script with 'red box' functionality utilising Ableton API.
- Traktor Pro 2 mapping and settings file with audio out to Ableton, MIDI clock Slave Sync - Tested working in Traktor Pro 2.5 (no sample deck operation - coming soon) .tsi
- Unencrypted Bome MT script file .bmtp
- Ableton Live template set featuring audio in from Traktor, MIDI clock Master Sync and 4 Send Return FX channels .als
- Setup Guide / Mapping Diagram / User Guide .txt
