Filter out midi timecode when capturing midi?
KenC
2012-07-08 08:33:40
I have a Saffire Pro 24 and for some reason it's always sending out midi timecode, I can't see anywhere to turn that off.
Problem is that I'm using an old Yamaha composer keyboard as a motherkeyboard and it has almost 100 buttons that all sends out sysex when pressed that I want to use and map to keyboard keys, but I can't see them because the constant stream of midi timecode erases the values immidiately and pushes them out of the list.
Any way to filter the midi timecode out when using the "capture midi" checkbox?
KenC
2012-07-09 08:25:42
Disregard, found a way to disable the timecode. It was buried pretty deep in the control panel options for my soundcard. :oops:
