Sakis wrote:Thanks for mentioning the MEP4.What a beast!never heard it before!More powerful than MIDI Event Processor from MIDI Solutions but I guess it was very difficult to program it...
Actually it
was a PITA to program but not because it was complex: it had its own display and a relatively simple structure, but because it was from the "use the least buttons possible" philosophy of the day, you ended up pressing or holding down buttons a lot to scroll through parameters and values. Once programmed though, it was very solid. Its biggest disadvantage was that they built it into a full-size steel rackmount case; not something you can just throw into the gig bag.
But it's greatest failure is that it was a very closed system: there was no way to include new processing algorithms. Today it would seem almost absurd to put so much effort in producing hardware like this for the limited processing it can do. In many ways MT is so much more evolved and integrated into our virtual environments; and the good thing is that it keeps evolving.
If you're still curious you should read the manual (available as pdf online) to get a better idea of what it did and how it worked.
