The Hui implementation for the Roland SI-24
H Mode (*7)
Transmitting message
This unit transmits message when value of fader, switch status or encoder position changes.
Knobs or Dials Controller No. Controller Value
FADER 1 00H ( 0) 00H - 7FH (0:bottom-127:top)
20H (32) 00H (0)
FADER 2 01H ( 1) 00H - 7FH (0:bottom-127:top)
21H (32) 00H (0)
FADER 3 02H ( 2) 00H - 7FH (0:bottom-127:top)
22H (32) 00H (0)
FADER 4 03H ( 3) 00H - 7FH (0:bottom-127:top)
23H (32) 00H (0)
FADER 5 04H ( 4) 00H - 7FH (0:bottom-127:top)
24H (32) 00H (0)
FADER 6 05H ( 5) 00H - 7FH (0:bottom-127:top)
25H (32) 00H (0)
FADER 7 06H ( 6) 00H - 7FH (0:bottom-127:top)
26H (32) 00H (0)
FADER 8 07H ( 7) 00H - 7FH (0:bottom-127:top)
27H (32) 00H (0)
Jog wheel 0FH (15) 0EH
2FH (47) 41H, 42H (65:Counter Clock Wise, 66:Clock wise)
2FH (47) 01H, 02H (01:Counter Clock Wise,02:Clock wise)
STATUS 1 0FH (16) 00H, 18H (0,24)
2FH (47) 00H - 05H, 07H, 40H - 45H, 47H (0-5,7:released, 64-69,71:pressed)
STATUS 2 0FH (16) 01H, 18H (1,24)
STATUS 3 0FH (16) 02H, 18H (2,24)
STATUS 4 0FH (16) 03H, 18H (3,24)
STATUS 5 0FH (16) 04H, 18H (4,24)
STATUS 6 0FH (16) 05H, 18H (5,24)
STATUS 7 0FH (16) 06H, 18H (6,24)
STATUS 8 0FH (16) 07H, 18H (7,24)
STATUS 11 4CH (26) 0FH (0)
STATUS 12 4CH (27) 4FH (79)
CH SELECT 1 0FH (15) 00H (0)
2FH (47) 01H, 06H, 41H, 46H (1,6:released, 49,54:pressed)
CH SELECT 2 0FH (15) 01H (1)
CH SELECT 3 0FH (15) 02H (2)
CH SELECT 4 0FH (15) 03H (3)
CH SELECT 5 0FH (15) 04H (4)
CH SELECT 6 0FH (15) 05H (5)
CH SELECT 7 0FH (15) 06H (6)
CH SELECT 8 0FH (15) 07H (7)
CH SELECT 9 0FH (15) 1CH (28)
2FH (47) 00H, 02H, 40H, 42H (0,2:released, 64,66:pressed)
CH SELECT 10 0FH (15) 1CH (28)
2FH (47) 00H, 03H, 40H, 43H (0,3:released, 64,67:pressed)
CH SELECT 11 0FH (15) 1CH (28)
2FH (47) 00H, 04H, 40H, 44H (0,4:released, 64,68:pressed)
CH SELECT 12 0FH (15) 1CH (28)
2FH (47) 00H, 05H, 40H, 45H (0,5:released, 64,69:pressed)
PAN 1 0FH (15) 0BH (11)
2FH (47) 02H, 42H (2, 66)
40H (64) 01H, 41H (1:Counter Clock Wise, 65:Clock wise)
PAN 2 0FH (15) 0BH (11)
41H (65) 01H, 41H (1:Counter Clock Wise, 65:Clock wise)
PAN 3 0FH (15) 0BH (11)
42H (66) 01H, 41H (1:Counter Clock Wise, 65:Clock wise)
PAN 4 0FH (15) 0BH (11)
43H (67) 01H, 41H (1:Counter Clock Wise, 65:Clock wise)
PAN 5 0FH (15) 0BH (11)
44H (68) 01H, 41H (1:Counter Clock Wise, 65:Clock wise)
PAN 6 0FH (15) 0BH (11)
45H (69) 01H, 41H (1:Counter Clock Wise, 65:Clock wise)
PAN 7 0FH (15) 0BH (11)
46H (70) 01H, 41H (1:Counter Clock Wise, 65:Clock wise)
PAN 8 0FH (15) 0BH (11)
47H (71) 01H, 41H (1:Counter Clock Wise, 65:Clock wise)
PAN 9 0FH (15) 1CH (28)
2FH (47) 00H, 40H (0,64)
40H - 4BH (64-75) 01H, 41H (1:1:Counter Clock Wise, 65:Clock wise)
PAN 10 0FH (15) 1CH (28)
PAN 11 0FH (15) 1CH (28)
PAN 12 0FH (15) 1CH (28)
40H - 4BH (64-75) 01H, 41H (1:Counter Clock Wise, 65:Clock wise)
EQ 1 0FH (16) 1CH (28)
EQ 2 0FH (16) 1CH (28)
EQ 3 0FH (16) 1CH (28)
EQ 4 0FH (16) 1CH (28)
PLUG-IN 0FH (56) 00H, 09H (0,9)
2FH (47) 05H, 06H, 45H, 46H (5,6:released, 69,70:pressed)
SHIFT 0FH (15) 08H (8)
2FH (33) 01H, 41H (1:released, 65:pressed)
5
Roland SI-24 MIDI Implementation
OUTPUT 0FH (15) 0AH (10)
2FH (33) 02H, 42H (2:released, 66:pressed)
BUS 0FH (15) 0AH (10)
2FH (33) 00H, 40H (0:released, 64:pressed)
Tr1-12 0FH (15) 0AH (10)
2FH (33) 03H, 43H (3:released, 51:pressed)
Tr13-24 0FH (15) 0AH (10)
MARKER 0FH (15) 09H (9)
2FH (33) 03H, 43H (3:released, 67:pressed)
0 0FH (15) 14H (20)
2FH (47) 00H, 40H (0:released, 64:pressed)
1 (*8) 0FH (15) 08H, 09H, 13H (8,9,19)
2FH (47) 00H, 01H, 05H, 07H, 40H, 41H, 45H, 47H (0,1,5,7,64,65,71)
2 (*8) 0FH (15) 08H, 09H, 13H (8,9,19)
2FH (47) 01H, 03H, 05H, 41H, 43H, 45H (1,3,5,65,67,69)
3 (*8) 0FH (15) 09H, 13H, 1AH (9,19,26)
2FH (47) 02H, 04H - 06H, 42H, 44H - 46H (2,4-6,66,68-70)
4 (*8) 0FH (15) 09H, 13H, 1AH (9,19,26)
2FH (47) 00H, 02H, 03H, 05H, 40H, 42H, 43H, 45H (0,2,3,5,64,66,67,69)
5 (*8) 0FH (15) 09H, 13H, 1AH (9,19,26)
2FH (47) 03H - 05H, 43H - 45H (0-5,67-69)
6 (*8) 0FH (15) 09H, 13H, 19H (9,19,25)
2FH (47) 03H, 05H, 07H, 43H, 45H, 47H (3,5,7,67,69,71)
7 (*8) 0FH (15) 13H, 15H, 19H (19,21,25)
2FH (47) 00H, 04H, 05H, 40H, 44H,45H (0,4,5,64,68,69)
8 (*8) 0FH (15) 08H, 13H, 15H (8,19,21)
2FH (47) 01H, 04H, 05H, 41H, 44H, 45H (1,4,5,65,68,69)
9 (*8) 0FH (15) 13H, 15H, 1BH (19,21,27)
2FH (47) 02H, 05H, 07H, 42H, 45H, 47H (2,5,7,66,69,71)
PAUSE 0FH (15) 0FH (15)
2FH (47) 00H, 40H (0:released,64:pressed)
REW 0FH (15) 0EH (14)
2FH (47) 01H, 41H (1:released,65:pressed)
FF 0FH (15) 0EH (14)
2FH (47) 02H, 42H (2:released,66:pressed)
STOP 0FH (15) 0EH (14)
2FH (47) 03H, 43H (3:released,67:pressed)
PLAY 0FH (15) 0EH (14)
2FH (47) 04H, 44H (4:released,68:pressed)
REC 0FH (15) 0EH (14)
2FH (47) 05H, 45H (5:released,69:pressed)
FADER 1 Touch 0FH (15) 00H (0)
FADER 2 Touch 0FH (15) 01H (1)
FADER 3 Touch 0FH (15) 02H (2)
FADER 4 Touch 0FH (15) 03H (3)
FADER 5 Touch 0FH (15) 04H (4)
FADER 6 Touch 0FH (15) 05H (5)
FADER 7 Touch 0FH (15) 06H (6)
FADER 8 Touch 0FH (15) 07H (7)
Receiving message
Controls fader movement and On/Off of LED.
20H (32) 00H (0)
21H (32) 00H (0)
22H (32) 00H (0)
23H (32) 00H (0)
24H (32) 00H (0)
25H (32) 00H (0)
26H (32) 00H (0)
27H (32) 00H (0)
STATUS 1 0CH (12) 00H (0)
2CH (44) 02H - 04H, 07H, 24H, 42H - 44H, 47H (2-4:Off, 7,36:green, 66-68,71:red)
STATUS 2 0CH (12) 01H (1)
STATUS 3 0CH (12) 02H (2)
STATUS 4 0CH (12) 03H (3)
STATUS 5 0CH (12) 04H (4)
STATUS 6 0CH (12) 05H (5)
STATUS 7 0CH (12) 06H (6)
STATUS 8 0CH (12) 07H (7)
CH SELECT 1 0CH (28) 00H (0)
2CH (44) 01H, 41H (0:off, 65:red)
CH SELECT 2 0CH (28) 01H (1)
CH SELECT 3 0CH (28) 02H (2)
CH SELECT 4 0CH (28) 03H (3)
CH SELECT 5 0CH (28) 04H (4)
CH SELECT 6 0CH (28) 05H (5)
CH SELECT 7 0CH (28) 06H (6)
CH SELECT 8 0CH (28) 07H (7)
CH SELECT 9 0CH (28) 1CH (28)
2CH (44) 02H, 42H (2:off, 66:red)
CH SELECT 10 0CH (28) 1CH (28)
2CH (44) 03H, 43H (2:off, 67:red)
CH SELECT 11 0CH (28) 1CH (28)
2CH (44) 04H, 44H (4:off, 68:red)
CH SELECT 12 0CH (28) 1CH (28)
2CH (44) 05H, 45H (5:off, 69:red)
SHIFT 0CH (28) 08H (8)
2CH (44) 01H, 41H (1:off, 65:orange)
1 (*8) 0CH (28) 08H, 09H (8,9)
2CH (44) 00H, 07H, 40H, 47H (0,7:off, 64,71:red)
2 (*8) 0CH (28) 08H, 09H (8,9)
2CH (44) 01H, 03H, 41H, 43H (1,3:off, 65,67:red)
3 (*8) 0CH (28) 09H, 1AH (9,26)
2CH (44) 02H, 04H, 42H, 44H (2,4:off, 66,68:red)
4 (*8) 0CH (28) 09H, 1AH (9,26)
2CH (44) 00H, 03H, 40H, 43H (0,3:off, 64,67:red)
5 (*8) 0CH (28) 09H, 1AH (9,26)
2CH (44) 03H, 04H, 43H, 44H (3,4:off, 67,68:red)
6 (*8) 0CH (28) 09H, 19H (9,25)
2CH (44) 03H, 05H, 43H, 45H (3,5:off, 67,69:red)
7 (*8) 0CH (28) 19H (25)
8 (*8) 0CH (28) 08H (8)
PLAY 0CH (28) 0EH (14)
2CH (44) 04H, 44H (4:off, 68:green)
REC 0CH (28) 0EH (14)
(*7) Unit transmits and receives multiple messages corresponding to singe operation.
(*8) Unit does not send or receive this when [SYSTEM] is lit.
