Muziekschuur
2012-09-12 18:32:03
What ohmage are midi cables. I checked some home made midi cables (got me a bucketload of amphenol screw 5 pin connectors... ) and some thin microphone wire. I checked the cables with the UM-880 (has a cable checker build in. (plug cable in 1 in and 1 out and press the check knob. Three lights on the first row will glow constant to let you know it's sending and receiving if it's blinking one of the three wires is loose) .
I purchased 4 new 2 meter cables. But I wonder if my old cables are ok or not. If not it could be a wrong ohmage cable... But I dunno... My Tascam DM24 should do HUI but I cannot seem to get it going. My SI-24 does work over the UM880....
