softcore
2012-10-12 19:36:31
Greetings and congrats for the great software. I am using Bomes Midi translator Pro almost a year now and have never had a problem figuring out the way to work with it, hence never being present in thse forums. lately, however, I 've been trying to fix a minor detail which is doing my head in and I cant.
Im using latest version (1.7.2) on Windows 7 64 bit. As you might now, when a USB midi device gets plugged in to a different port in your system, it is renamed with a number in front of its name. My launhcpad has, over the times, been plugged to 3 different USB ports - making the system presenting the device as "Launhcpad", "1-Launchpad", etc etc. Now my problem is, I have steadily been using it on one given USB port, in my DAW it is presented as "Launchpad", it is present in Bome's Midi Translator but whenever I start it, a pop up message that
"3-Launchpad" could not be opened - use a different midi port in the Midi setup". The weird part however is that NONE of my translators use "3-Launchpad". In other words it shouldnt be referenced. I even tried with a new blank project, created a translator with the working Launchpad ports yet still every time the software is started it references the non existent "3-Launchpad".
In the Midi settings there is, again no reference anywhere to "3-Launchpad"
I also noticed that upon creating a new alias, the option to use "3-Launchpad" is there (and of course if I select it it remains pending). How do I make Bome's Midi Translator disregard the once existent "3-Launchpad" port which is now irrelevant?
I tried cleaning my system from "ghosted" midi devices (it also involves a registry hack so that those can be actually visible in device manager) yet still, no luck.
Everything is working perfectly but the reason I want to fix this minor detail is because I sometimes work in clubs or radios and whatnot and upon switching on all my stuff, I dont want to have pop up alert messages falsely alarm me. I want my system to notify me only when indeed something is unplugged- not working.
Thanks in advance!
Thanks in advance!
