gabriels
2012-10-17 07:42:49
I'm having a problem with the following setup:
This much works well:
Midiox -> outputs to Bome Virtual Port 1 Out
MTPro instance 1 inputs on Bome Virtual Port 1 In
MtPro instance 1 outputs on Bome Virtual Port 2 Out
But when I add another instance of MTPro like this:
MTPro instance 2 inputs on Bome Virtual Port 2 In
Then the second instance of MTPro doesn't see the data, and in fact, the First instance stops receiving data from Midiox.
I can make this setup work with only Midiox and MidiYoke. This works:
Midiox outputs on MidiYoke1 Out
MTPro instance 1 inputs on MidiYoke1 In
MTPro instance 1 outpus on MidiYoke2 Out
MTPro instance 2 inputs on MidiYoke2 In
Can someone shed some light on why MidiYoke works but MTPro Virtual Ports don't in my case?
Gabriel
Gabriel
