Hi DvlsAdvct,
Thanks for quick response.
I have a M-Audio Prokeys 88 keyboard and I am using Ableton Live 8 and lots of VST's. What I want to do is actually quite simple. I want to assign some of my VST's into Ableton's tracks and when I hit my program changer pedal, Ableton switches to next track and arm that particular track only, so I can play on stage.
I was searching internet to do this and stumbled upon your software, decided to give it a try. When I hit my pedal, it sends two midi signals as "pedal down" and "pedal up". Which is good since I thought I could assign the first signal to switch to the next channel and second to arm the track. I could somehow manage to arm the track with my pedal but no matter what I do "switch to next track midi signal" does not work on Ableton Live 8. To arm the track i am using a particular midi message (90 00 f7 in this case) as outgoing action and it works. But when it comes to selecting the next track I have to use Keystroke emulation and eventhough it works with notepad, it doesn't work with Ableton Live 8.
So I thought the problem is maybe with Ableton. I did a little bit searching and came across these topics.
http://www.bome.com/forums/viewtopic.php?f=3&t=2740http://www.bome.com/forums/viewtopic.php?f=3&t=3113
Other than downgrading to XP or using two monitors, none of these threads come up with a decent solution.
I've decided to try my luck by downloading Ableton Live 7 and trying it again voila! both commands are working. Butl I'd still prefer to use the program with Live 8 instead of Live 7.
Note: I am using win7x64, ableton live 8.0.1, m-audio prokeys 88 connected via usb to my laptop, midi ox and MT for whole process.
Thanks in advance.
Sheri
