2012-11-06 23:10:11
Hi, here I'll outline how you can control the mouse with a MIDI touchpad.
In the example, I use the Korg NanoPad. It sends Controller #1 for up/down: value 0 at bottom and value 127 at top. For the horizontal (left/right) direction, it uses pitch bend.
For each message from the pad, I calculate the difference of the new value minus the last value.
For up/down movement (CC#1), if the difference is positive, the mouse pointer is moved down a bit (Translator 0). Otherwise, in Translator 1, the mouse pointer is moved up a bit. Note that you do not need to recalculate the difference there, because the global variable gd remembers the current difference.
For left/right movement, the logic is the same. Since it is a pitch bend message, correct would be to calculate the full value. However, the NanoPad does not send a fine grained pitch bend anyway, so only the high byte is used for calculating the difference.
Global variables:
gd: current difference of position in up/down direction
gy: last position in up/down direction
hd: current difference of position in left/right direction
hy: last position in left/right direction
Hope this helps!
Translator 0: Down
Options: stop=false
Incoming: MIDI B0 01 pp
gd=gy-pp
gy=pp
if gd<0 then exit rules, skip Outgoing Action
Outgoing: Mouse move 10 (down)
Translator 1: Up
Options: stop=false
if gd>=0 then exit rules, skip Outgoing Action
Outgoing: Mouse move -10 (up)
Translator 2: Right
Options: stop=false
Incoming: MIDI E0 pp qq
hd=pp-hy
hy=pp
if hd<0 then exit rules, skip Outgoing Action
Outgoing: Mouse move 10 (right)
Translator 3: Left
Options: stop=false
if hd>=0 then exit rules, skip Outgoing Action
Outgoing: Mouse move -10 (left)
Global variables:
Hope this helps!
