Send more than one out from an in?
fingerpuk
2012-11-11 13:16:25
Hello.
I'm re-mapping my APC20 for use with VDMX. One thing I can't work out is how to configure the lights, I want to be able to send out commands to 5 buttons to switch the light when one button is pressed, but not have this output go to VDMX. I thought about adding an extra virtual port and linking this to the APC20, then send multiple midi hex values. I've tried this, but I think the APC in Bome is only seen as an input (it's on the left of the router chart and my virtual port number 3 is on the right).
So my questions are:
<> is a virtual port specifically for lighting commands a sensible solution?
<> can I send midi back tot he APC20 from Bome?
<> if so, how do I connect VP3 to the APC20 in?
Thanks.
fingerpuk
2012-11-11 13:45:17
I have this working now, all I need to work out is how to send '90 52 31 90 53 31 90 54 31 90 55 31 90 56 31' 500ms after receiving the input.
DvlsAdvct
2012-11-11 16:12:41
At the bottom of the translator window in the Outgoing Action window there is a little delay section. The last one says Delay in milliseconds. Put 500 in that box and you should be good.
fingerpuk
2012-11-11 16:41:50
Cheers, I hadn't upgraded so didn't have that.
