"capture midi" show incoming data
aleghibson
2012-11-13 14:21:57
Hi
It can be handy to use "capture midi" data only from a specific port (if chosen) on a translator and don't close the window when disable "Capture MIDI" and show all data entry.
best regards
Alessandro
2012-11-13 21:30:17
Hi, thanks for the request. This will come! The second feature (keep the capture window without capturing) is already available in the OSX version and will make it into the Windows version, too.
aleghibson
2012-11-16 15:48:00
Hi MR Florian,
tks for fats answer. I'm usinsing V1.72 build 1285 update on XP.
best regards
Alessandro
