Your own MIDIYoke? A Manual?
rsodre
2006-11-19 20:00:13
In the lack of a proper manual, I figured it out we need to install MIDIYoke to work with MIDI Translator (thanks to the bcd2000-traktor PDF!).
Or am I missing something here?
Why don't you create your own MIDIYoke to mimic MIDI TRanslator outputs?
BTW, what about a manual?
2006-11-19 22:23:06
good points, and indeed, both are top priority already! I've already a virtual driver in the queue (which is not trivial to do, therefore the "why not earlier"...), and a manual must be done asap, too (though the current readme has some information).
You need MIDIYoke if you want to route MT's MIDI output to another MIDI app (or, route an app's MIDI output into MT). Actually, it depends a lot on what you're using MT for if you need Yoke or not.
Thanks and best regards,
2009-03-27 17:32:58
as of version 1.7 for Windows and 1.6 for Mac, Midi Translator ships with its own virtual MIDI port(s). Try it!
