Errorcode 14 when installing Midi driver suport W7 x64
pn2013
2013-01-23 15:14:48
Hi i got Error code 14 when installing Midi driver support W7 x64.
Any ideas ?
Best regards
Eric
DvlsAdvct
2013-01-29 18:24:54
Hi Eric
Sorry for the long response. You posted once I left for NAMM.
Can you try completely uninstalling everything and reinstalling from scratch?
If that doesn't work I'll let Florian know.
pn2013
2013-01-29 20:27:52
I have had contact with Florian who really tried to help me, but the problem was that my system permission was FUBAR.
I now got i all working!! :-)
Eric
Steril
2013-05-27 21:04:22
I´ve got exactly the same problem. I had previously installed them, then uninstalled them, Now, a re-install ´ll not work with error code 14.
Custom Install with "force midi driver reinstall" don´t work either...
Any ideas?
Steril
2013-05-27 21:10:27
I´ve got the same problem. How did you fix it?
2014-02-18 14:43:05
discussion is continued here:
BOME Virtual MIDI port error 14
