sometimes, the problem is that keys are triggered to fast from Midi Translator. Then it helps to differentiate "key down" and "key release", and send the "release" with a delay.
E.g. if you want to press letter A on incoming MIDI Note 64 (hexadecimal 40), do this:
Translator 0:
[ ] stop processing
Incoming: 90 40 7F
Outgoing: Key Down: A
Translator 1:
[ ] stop processing
Incoming: 90 40 7F
Outgoing: Key Up: A
[x] delay 10ms
For keystroke combinations, rip them apart like this for ALT+H:
Translator 0:
[ ] stop processing
Incoming: 90 40 7F
Outgoing: Key Down: ALT
Translator 1:
[ ] stop processing
Incoming: 90 40 7F
Outgoing: Keystroke/Sequence: H
[x] delay 10ms
Translator 2:
[ ] stop processing
Incoming: 90 40 7F
Outgoing: Key Up: ALT
[x] delay 15ms
Of course, the incoming action will probably be different for you, and you may need to experiment a bit with the delays.
We plan for a future version to have a "slow keystrokes" option so that MTP will do the delaying on its own.
