MT doesn't show interface anymore.
audiosync
2013-02-02 16:33:12
I am autostarting my project minimized and it worked well for the last week.
But today the interface didn‘t come up when i click the tray icon!
I rightclicked the tray icon and selected 'show' but it doesn't show.
I reinstalled MT (+clean up my documents folder, reboot, reinstall) without success.
If i rightcklick trayicon and then MIDI / MIDI Ports the settings dialog opens. I then deselect the options „Start Minimized“ and „Autostart with Windows“ (which it seems to have kept during deinstallation) and rebooted the whole computer but guess what: I still only have a tray icon but that’s it…
I am using Windows 8 64bit.
Sakis
2013-02-09 20:28:03
You could check the "Midi Translator Window Vanished" thread:
http://www.bome.com/forums/viewtopic.php?f=4&t=3792
Do you use ClassicShell http://www.classicshell.net/ for Windows 8 ?Although it restores the classic desktop power ,it may causes trouble on some apps...(but it didn't caused MTpro any troubles ,for me at least)...
audiosync
2013-02-09 22:13:49
Thanks. I already deleted everything called "bome" in my registry and it is working again.
