Controlling System Volume with BCF2000
tobybennett
2013-03-01 13:30:41
Noob question here; I have searched, but I can't find any answers.
Is there any way of using Bome MT to translate a CC message on my BCF2000 to control my system volume?
At present, I can assign keystrokes from my keyboard which adjust volume, but then obviously will not work on a slider.
Toby
DvlsAdvct
2013-03-02 00:28:38
Hi Toby
If you can set keystrokes to the command then you can set translators for it. What you would need to do is arrange global variables to recognize whether the fader is moving up or down, and once it figures that out it would send the keystroke command.
http://www.bome.com/forums/viewtopic.php?f=3&t=3657
That thread should walk you through exactly what you need.
Let me know if that doesn't help.
Jared
