Saving Bug Empty Translators
bobbyquine
2013-03-26 13:37:10
Hi I've just worked out why after saving my project bits were suddenly missing from presets...
Its because I started using empty translators to visually manage groups of processes within a preset, but after a save, any translator below the empty one is deleted. Don't know if this is intentional....
Anyway, don't use empty translators!!
B
DvlsAdvct
2013-03-27 00:43:48
That definitely shouldn't happen. I'm going to move this to the Bug forums and alert Florian.
2013-03-27 08:18:59
Hi Bobby,
thanks a lot for reporting this and warning people. I cannot reproduce it, could you please tell me if you're on Windows or Mac, and which version of MT you're using (see the About window)? Thanks!
bobbyquine
2013-03-27 09:42:18
Hey Florian,
It's 1.7.2 build 511
I'm on Mac OSX 10.8.2
Hope I didn't make a mistake!
Best regards
B
2013-05-25 15:58:37
thanks anyway, will double-check that this cannot happen in the next version.
