ModeratoMaestoso
2013-05-31 09:06:22
Hi guys,
Is it possible to build pauses into keystroke outputs (or at least separate them)?
I want to set my upper keyboard to insert program changes into the Sonar timeline. This involves using keystrokes to emulate going into the menu item "insert / program change" and then tabbing in the dialog that comes up and inserting a number, and then pressing "ok".
So the keystrokes are (for example):
"Alt, I, P, tab, tab, 127, enter"
Can I do this with Bome's MT?
Cheers,
Martin
Cheers,
Martin
