great Korg padKontrol Resource for sysex
famusvictim
2013-06-11 13:39:45
If you want to control your padKontrol in realtime, then this guy has written a great SysEx compilation - working great for me.
http://static.twoday.net/kpkproject/fil ... ex-Imp.pdf
rock on
makerprofaze
2013-07-06 19:00:57
I have tried everything to get my padKontrol to enter Native Mode, and I'm somewhat convinced it's faulty. I just got a microKontrol recently, and from THIS I came up with this Native Mode block for the microKontrol:
f0 42 40 6E 00 00 00 01 F7 f0 42 40 6E 00 3f 27 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 f0 42 40 6E 00 3F 12 01 00 00 00 00 33 33 33 33 03 53 50 41 20 4C 53 30 31 F7 f0 42 40 6E 00 3f 21 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 f0 42 40 6E 00 3f 21 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7
I don't understand all the parts, but I can change the LED states/colors, and use ASCII text codes for the LCDs. The Octave buttons still work in standard mode (color/reset octave both buttons). I've just started, but this is enough raw MIDI for BMTP to take over.
Could you post a similar code I can use in BMTP to put the padKontrol in Native Mode?
[maybe I should have posted this on the other (duplicate) thread... think I will]
