lionelcassin
2005-07-20 04:22:16
I currently control my beloved Ensoniq DP/4 with Unisyn. Unisyn appears to control the DP/4's parameters with sysex messages. I sniffed the messages that Unisyn sends out when, for example, the Mix parameter in the first effects unit is set, respectively, to minimum and to maximum:
F0 0F 40 00 00 01 00 01 00 00 00 01 00 00 00 00 F7
F0 0F 40 00 00 01 00 01 00 00 00 01 00 00 07 0F F7
I would like to control the DP/4 with a hardware MIDI controller (see PS below). I sniffed the output from a continuous controller knob on my Kurzweil PC1X:
B0 0D 00
B0 0D 7F
So, it looks like where the Kurzweil says "7F", the Ensoniq expects to see "07 0F". Is this a problem? Is there any way I can use MT to translate between the two? How would I use
My eventual plan is to get a Behringer BCR2000 or equivalent. Does that change the equation?
Lionel
PS - The DP/4 has a feature where two parameters in each effect can be controlled by MIDI continuous controllers, but there are far more than 2 parameter I'd like to control with a knob.
B0 0D 00
B0 0D 7F
Lionel
