ziguigwi
2006-12-05 22:37:30
do you now about using midi translator to input midi into Flash swf
merci
Pascal
2006-12-06 09:05:36
Hi Pascal,
I don't know the possibilities with flash very well, but in principle the following should work to control flash from MT:
Use the MIDI to KEYSTROKE function in Midi Translator. For each MIDI command that you want flash to receive, define a translator with Outgoing Action a keystroke, e.g. 90 40 pp (Note On) gets translated to Ctrl-A. Now when Flash is active, it'll think that you pressed Ctrl+A on the computer keyboard. Of course you can use any key combination.
Hope that helps!
