I've tried again, and everything works fine! I had to restart MT to activate Keystroke Input after activating it in the list of "accessibility" programs.
At first, I've used a super simple preset with just one translator entry:
Incoming: Keystroke: M
Outgoing: Keystroke: N
Then I switched to text edit, and pressed the key "M". MT then types "n" on its own.
I've also tried with shortcuts.
Can you describe in detail what you've done?
PS: note that keystrokes are disabled when MT is the active application (otherwise it could get very difficult to edit presets...)
