WayneC
2006-12-18 06:38:58
I'm almost there..
I'm trying to program my laptop's delete key to work with a pad from my DrumKat. The Drumkat is a midi device, each pad has a separate midi note.
So far, in BOM I have the input configured to the Firebox that the Drumkat is connected to(Firebox midi in). I have the output configured to NT1. I programmed the drum pad into a preset via midi capture, and set the keystroke as the delete key. So far, so good.
In Ableton Live I set a midi channel to receive midi in from NT1. I don't get any midi input from the drumpad, and the drum pad does not trigger the delete key.
When I remove BOM, I can use the Drum pad via the Firebox Midi In with no problems.
I'm sorta lost here. What am I missing?
Thanks. If I can get this to work I will be KING OF THE UNIVERSE!
Wayne
Wayne
