rtx1224
2013-12-24 09:26:06
hello.
for a long time i have been trying to achieve the ability to control a VSTi with my behringer BCR2000 (plus keyboard) and get patch parameter feedback, however ive never been able to solve actually it has turned me off from making music on a computer abit.
someone on KVR recommended your software (MidiTranslator) and I wanted to ask if in fact this will work for my needs and if yes, then which version do I need?
I'll explain specifically what I need:
I have a Novation remote 49SL patched into my laptop via usb running cubase 5.
a behringer BCR2000 is patched into the novation via midi (BCR out into Novation In) more on that later.
I would like to use the Novation/BCR combo to control VSTi's and VSTfx.
I don't care about controlling cubase itself; only the VSTs.
I want to setup my BCR with permanent labels so that I am always controlling the same vsti synth parameters with the same knobs (like a hardware synth) regardless what vsti I have open.
so for example the same physical knob will control the filter cutoff for NI Massive, u-he Zebra, etc...
so all of the BCR's 32 knobs are controlling synth parameters.
Id like another page or bank (of the BCR) for VSTfx control, so that I can assign all 32 knobs as a super-channel regardless what VST is open at a time. so if i assigned knob 1-4 for compressor parameters and 5-8 for reverb control, and have a chanel strip plugin opened that has both of those fx then all the knobs would work, and if i have only a compressor opened then only knobs 1-4 would work, etc...
whats really important to me as well is to get patch parameter feedback into the BCR.
so if i change a patch on a VSTi (say from one that has a fast attack to one that has a slow attack) that information will be sent to the BCR and the LED on that attack knob will change accordingly .
so will Midi Translator work for me?
if yes, which version do I need to buy?
will I need to open any preset within MidiTranslator when Im opening a new VSTi?
will I be limited to VSTi's that have midi learn capability?
will the setup work in the current configuration? or do I need to have the BCR plugged into the laptop via USB (this is a problem for me at the minute as I am unable to get the behringer drivers to be recognized by win7/64)
Thanx for reading,
here is my original post on KVR in case it is still not clear as to what Im trying to achieve.
http://www.kvraudio.com/forum/viewtopic ... 82#5601582
Thanx for reading,
