unfortunately I can't really help you much myself. We're working on a manual for Midi Translator to ease the learning curve. But I have neither Traktor nor the BCD2000 device for specific help. Maybe someone else with that configuration can jump into this discussion.
As a general outline, it works like this:
- download Midi Translator Pro demo 1.5 from
http://www.bome.com/midi/translator/download.html
- install it. In
"C:\Program Files\Bome's Midi Translator\Presets Pro" you'll find:
- "BCD2000 (V1.1.1.0) and TRAKTOR 3.bmtp": to be opened in
Midi Translator Pro
- "BCD2000 (V1.1.1.0) and TRAKTOR 3.tks" to be opened in
Traktor
- "BCD2000 (V1.1.1.0) and TRAKTOR 3.pdf" a quick guide how
to install.
- also install a virtual MIDI device, like Yoke, see
paragraph 1.1 here:
http://www.bome.com/midi/keyboard/help/rsn3_tut.php
If there's anything that doesn't work, please reply to this forum thread. Bome.com staff and other people may have the right solution for you. Please be as specific as possible where you don't know what to do next. Usually, there are too many possibilities what can be wrong than to be able to reply to a general request.
Thanks, and good luck!
PS: a positive side effect of using the forum is that others who have the same problem will be able to find their solution here, or to join the discussion.
