Need MK 2.0 beta 6
klerg
2007-11-08 07:21:29
Where can i download MK 2.0 beta 6? I have XP SP1, and for some reason, MK 2.0.0 doesn't work for me. Some keys won't make a sound, others give me stuck notes, and the mouse wheel won't work sometimes either. Using MS GS Wavetable synth for my output. I do NOT have these problems with 2.0 beta 6. If someone could PM or e-mail beta 6, i'd be very thankful.
2007-11-08 14:21:51
Hi klerg,
sounds like a bad issue with the final version 2.0! We will work hard to fix this. I'll send you the old beta 6, and please report back your findings.
klerg
2007-11-08 19:28:41
These issues could be related ONLY to XP SP1, right? Do you need my e-mail address? Or do you already know it?
2007-11-08 21:01:02
yes, I got your email address. the email to you bounced because GMail doesn't accept .exe attachments. I try now with .zip attachment.
klerg
2007-11-09 01:00:46
Got it! Thanks very much for the quick, prompt response.
