Disabling MK's MIDI keymap
adXok
2008-08-19 09:45:46
How can I disable MIDI keymap layout in MK?
I want to use my custom keymap from MT, pass thru MK (for using its pitch and mod wheels but not keys) and go to my DAW's sequencer or Reason?!
Now it makes conflict between both MIDI maps: my custom MT and the non-editable MK's.
Any soluton?!
2008-10-21 11:35:57
hi, sorry for the late reply. Currently, you cannot deactivate MK's response to keystrokes. Changing the MIDI channel in MK also won't help, I guess, because then the mod wheel and pitch will also use that other channel... hmm. I'll add it to the TODO list in MK.
