Alec
2009-02-05 04:46:52
Great piece of kit
; seems to snap into Reason 4 pretty easily.
However, latency of about 250ms is severely affecting performance.
(Key press to audio signal = 250 miliseconds.)
Isolating the problem:
1 - Tried changing latency settings in Reason down to 5ms (min), but no discernible effect.
2 - Reinstalled and checked again this time with BMK as standalone; NOT patched to Reason; no MIDI Port Driver (uninstalled), and latency is the same; still 250ms. I press a key, and a quarter of a second later I get a reaction (note-on) from BMK. So it seems my latency problem is with BMK, not Reason. Anyone know how I can reduce the latency?
Definitely up for paying the (miniscule!) license fee if I get the latency issue sorted!
If it helps:
Compaq V3700 (SCSI hard drive on this model), WinXP Pro SP2, [also LoopBe1, Reason 4.0; but latency issue is present independent of these applications].
If it helps:
