Serratus
2009-08-15 14:51:45
Hello!
First of all - thank you for this amazing prog! It helped me so much!
Second: Sorry for my bad english - I'm russian and not very good with learning languages!
I have a some (maybe difficult to implement but very, very useful) feature request:
I want to use pedals from my Logitech Wingman Formula wheel. I know I can map some joystick axis to some MIDI controller knob, but there is "one tiny little problem" (not one in fact but two):
1. I can only map both pedals as a single axis (Joystick 0 Up/Down)
2. I can't map any pedal in separate axises mode at all.
Oh! And 3. When pedals are mapped in single axis mode, I can't use sustain controller normally cause it always ON! And when I press BRAKE pedal it is off! (It's logical because in single axis mode when no pedals pressed it's the MIDDLE position of the controller (no accel & no brakes) )
It would be great if in next version of MK it will be possible to map ANY Joystick/Whell/Rudder/(I don't know else what) axis/button to any of the MIDI controllers.
Thank you and best regards!
Alexey Maslov.
Alexey Maslov.
